Translating UNKNOWN on H323 FXO
carscadden
I have an h323 FXO gateway, plar'ing inbound calls to a couple of IP phones ... looking to translate UNKNOWN calling party number to a specific trunk id "911-1", "911-2" per 3rd party app company's request. Possible?
TIA,
Brian
Aaron Harrison
Hi Brian
Take a look here :
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_voice_configuration_library_glossary/vclclid.html#wp1077886
Looks like station-id should fill in the blank where no CLI is presented to the FXO.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks for the reply. I had tried that however it still displayed "UNKNOWN" at the station. I plan to try 'station-id number' or perhaps a translation rule. I'll post an update once I get it sorted out.
Any other ideas greatly appreciated.
Brian
Station-id number solved the problem. In what appears to be a config dependency, station-id number is required for the station-id name to display at all.
