01-08-2013 06:51 AM - edited 03-16-2019 03:02 PM
I need to configure some abbreviated patterns for a site, so I'm using Translation Patterns, for instance:
2000 --> 0444555666 (Mobile Phone of Manager A)
2001 --> 0555666777 (Mobile Phone of Manager B)
Managers don't want to publish their mobile numbers, so I have configured Connected Party Transformations in order to mask the number. Now, when a user phones "2000", in the IP Phone display "Private" can be read.
Is there anyway to change this "Private" with a label defining the number, for instance, "Mobile ManagerA"? I have tested several configurations, but it seems that it is not possible mask the number and send the name. Can anybody help me? Thanks!
01-08-2013 07:20 AM
Somebody from Cisco told me that it could be possible to do it through a TCL script in the gateway. Does anybody think that this could be a good solution?
01-08-2013 08:06 AM
You can achive this using Mobile Connect (Single Number Reach) instead of Translation Pattern". Just need to created a "Phamton Phone" 2001 so when the phone is called will send the call to the Mobile Phone without change de called number information...
Follow this guide.
https://learningnetwork.cisco.com/docs/DOC-4140
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
