10-20-2009 04:24 PM - edited 03-15-2019 08:09 PM
My SIP provider sends me all ten digits. I am trying to configure a translation pattern that would strip all but the last four digits.
Let's say my telephone number is 281-330-8004, I would like the gateway/CUCM to ring extension 8004.
How can I properly configure this? Is it better to configure the translation pattern on the gateway or on CUCM?
Thanks!
Solved! Go to Solution.
10-20-2009 05:49 PM
It's better to not configure any, unless you have a good reason to use a TP.
Under SIP trunk (or any GW, trunk, etc) there is a field called significant digits.
It defines how many digits from right to left CUCM should consider for routing.
Set it to 4 and only the last 4 digit will be used for routing within CUCM.
java
if this helps, please rate
10-21-2009 01:41 PM
The route pattern to the SIP trunk should have the checkbox to use the external phone number mask to be used, or to place the mask on the route pattern.
java
10-20-2009 05:49 PM
java
10-20-2009 06:57 PM
Thanks, that was just was I needed to resolve this issue. :)
10-20-2009 07:12 PM
I made that change, and now external callers just see the last three digits as their incoming caller-id.
For example, my number is 281-330-8004, if I call my cell phone I see a caller-id of 004. Any ideas? Thanks!
10-21-2009 05:13 AM
Set the Mask on each phone to send 281330XXXX and it will send the number as 10 digits and the last four will be your users ext.
Or you could put in your company main number and that will be what is sent out. the sig digits will only apply to inbound.
10-21-2009 01:36 PM
Is there anything else I could check? I have set my mask to 281330XXXX and it's still sending out 004 as the caller-id.
Thanks!
10-21-2009 01:41 PM
java
10-21-2009 01:45 PM
That fixed it, I just checked "Use Calling Party's External Phone Number Mask" on the route pattern and caller-id is now working as expected.
Thanks again!
