translation-rule problem
david.sua
Hi all,
I have a translation problem, I know where is it, but I don´t know why.
I have this config,
voice translation-rule 20
rule 1 /^941296*/ /6/
rule 2 /^941257115*/ /2290/
rule 3 /^941244606*/ /2291/
rule 4 /^941249882*/ /2292/
rule 5 /^941253246*/ /2293/
rule 6 /^941256652*/ /2294/
rule 7 /^941256657*/ /2295/
rule 8 /^941258657*/ /2296/
But when I call to number 941256657, the rule 6 translates the number to 22947.
Here is the output of "test voice translation" command,
CUBE2901#test voice translation-rule 20 941256657
Matched with rule 6
Original number: 941256657      Translated number: 22947
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Somebody have any idea?
Thanks in advance.
2 Accepted Solutions
Ayodeji Okanlawon
David,
The first question to ask is why do you have a * at the end of your rules...If the numbers you are dialling are specific then use speficis rules e.g
rule 7 /^941256657/ /2295/
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
As mentioned above remove the * at the end and it will work as expected.  "* Modifier—match none or more occurrences"
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml.
Ayodeji Okanlawon
David,
