Trap or SNMP MIB if an endpoint unregister from the CUCM
Mahmoud Simrin
Is there  any trap or SNMP MIB if an endpoint unregister from the CUCM ?
Thank you
5 Replies 5
Harmit Singh
Hi Mahmoud,
CISCO-CCM-MIB/CISCO-CCM-CAPABILITY MIB
The CISCO-CCM-MIB contains both dynamic (real-time) and configured  (static) information about the Cisco Unified Communications Manager and  its associated devices, such as phones, gateways, and so on, that are  visible on this Cisco Unified Communications Manager node. Simple  Network Management Protocol (SNMP) tables contain information such as IP  address, registration status, and model type.
SNMP supports IPv4, although the CISCO-CCM-MIB includes columns and storage for IPv6 addresses, preferences, and so on.
The following links talk in more detail about the same:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_6_1/admin/sasnmdes.html
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-CCM-MIB
HTH.
Harmit.
Hi Mahmoud,
It should be this:
"ccmUnregisteredPhones"          "1.3.6.1.4.1.9.9.156.1.5.6"
It's given in the link I gave you earlier. Here are all the OIDs for CISCO-CCM-MIB:
ftp://ftp.cisco.com/pub/mibs/oid/CISCO-CCM-MIB.oid
HTH.
Harmit.
Is there a specific test for  me to perform that is supposed to generate a specific trap based on the above OID?
Hello Harmit,
Does the above OID generate trap ? We are looking for a trap when a device gets unregistered from the CUCM.
