02-25-2015 10:42 PM - edited 03-17-2019 02:07 AM
Hello Community,
We've added new PRI to our single PRI. PRIs are controlled by a 7.1.5 CUCM via MGCP, we are using 3925 15.0(1r)M16 for gateway.
Now, we are configuring SRST/mgcp fallback... I am wondering if i can assign the PRIs to a Trunk group; would it cause issues with MGCP or when it goes to SRST mode?
Thanks in advance!
Solved! Go to Solution.
02-26-2015 04:02 AM
In SRST, the mgcp application is not active. The fall back is to H323, so there is no impact on your trunk groups or mgcp
02-26-2015 06:54 PM
Ramon,
When running MGCP, Q.931 media is backhauled to CUCM so you should be ok. The trunk group will come into play when your dial-peers are used, this will only happen during SRST in h323 mode.
FG
02-26-2015 04:02 AM
02-26-2015 06:34 PM
Thanks Ayodeji! I worry the trunk group command under Serial interface would have impact to mgcp application.
02-26-2015 06:54 PM
Ramon,
FG
02-26-2015 07:35 PM
Thanks Francisco!
