trunkgroup fxo
techguy
Level 4
Level 4
I have 2 analoge lines terminated on fxo ports. I have created on trunkgroup and it is called on each voice-port. Same trunkgroup is also called on all dial-peer. The problem is that if 1st line is busy its not selecting another line in trunkgroup. Any clue
6 Replies 6
Ayodeji Okanlawon
Try this..
trunk group SRSTPSTN (change this to your trunk group name)
max-retry 4
voice-class cause-code 34
hunt-scheme round-robin both down
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
paolo bevilacqua
Are you referring to incoming, or outgoing calls ?
@aokanlawon i will try and let you know.
@Paolo for outgoing calls
Update IOS. Re-hunting on member is supposed to happen with default configuration.
Paolo,
I am running "2900-universalk9-mz.SPA.150-1.M4.bin" and I had to use that work around to make hunting happen. I had the same issue too. With E1 ISDN hunting happens automatically, but not on the fxo ports. I am not sure why..
ciscovoiceguy
Hi Paolo,
Connect only first FXO line and make a test call,if there is busy line directly connect analog phone and make a test call if not please check with Service Provider.
