05-20-2018 10:01 PM - edited 03-18-2019 12:25 PM
how can i setup a phone so that when DN it is not pickup on certain seconds, it will fowarded to the handphone ?
i put handphone number under call foward and call pickup setting but when tried , it keep connecting to the cisco unity
i dont know if it is possible or not ?
05-21-2018 03:09 AM - edited 05-21-2018 03:09 AM
05-21-2018 06:21 AM
You need to have the Call Forward No Answer (CFNA) setting defined for the desired number and make sure you do not have a check in the "forward to voicemail" box.
05-21-2018 10:17 AM
Hi there
May be the Voicemail option is ticked mark on your call forward settings. Remove that and add your destination number and select the appropriate Calling Search Space.
Hope this helps !!!
Cheers
Rath!
***Please rate helpful posts***
