Turning beeps off for incoming calls
arsparks
Running CUCM 7.1.5.
Normally, when off hook, when an additional phone call comes in you hear a beep.  Is there any way to disable that?
Rob Huffman
Hi Al,
The setting that comes into play in your scenario
On the IP Phone config (under Directory Number Configuration);
Line Settings for this Device
Ring Setting (Phone Active) Flash Only
This can also be set on a Clusterwide basis;
Clusterwide Parameters (Device - Phone)> Ring Setting of Busy Station*> Flash Only
Cheers!
Rob
