UC Application Migration(V2V)
Siva chinap
Level 5
Level 5
Dear All,
We are in the midst of migrating to new hardware; application currently installed was CUCM,CUC& IMP in version 12.0, but we intend to migrate these applications to new hardware and upgrade to version 14. Could you please assist me with the PCD migration and upgrading procedure and Files required?
Please note we are intend to with simple migration using PCD, with same network information of old cluster. Can we completely migrate CUC & IMP cluster using PCD?
18 Replies 18
I Just completed 2 migrations using PCD and another 10 going to start from next week..
PCD is so easy..
And I always recommend this to my friends..
Response Signature
@Nithin EluvathingalDo i required any cop files to download for PCD Migration?
Upgrade readiness cop you need to.pre upgrade will check if you are good for an upgrade.
also there is a post upgrade cop also.
Refer the PCD admin guide correspond to version you are using.
It’s mandatory to read below.
Release notes
Install upgrade guides
pcd administration guide
compatibility matrix guides
Response Signature
hi Siva,
yes, you should be using the cop file. Its well explained in the following doc - here
Run pre-upgrade-check COP file needs to install on your existing UC servers.
Strongly recommend going through the migration steps and PCD documentation before you try out the migration.
