UC500 and Remote Phones / Teleworker
lus
Hello
As written on cisco.com the UC500 8/16 User support 2 remote phones. The other versions 24/32/48 support 4 remote phones.
I need to install now a 16 user version with a remote office. there will be 2 phones and 1 ata in the remote office.
An other project is with the 48 user version and 2 remote offices. Every remote office will have 3 phones, also a total of 6 remote phones.
The idea is to simply connect the remote phones over a site-to-site vpn tunnel with the uc500.
I have done this several times with callmanager express and it worked great.
How is this now with the uc500? It is technical not possible, because of the remote phone / Teleworker limitation? Or is it only a issue with the license of the phones?
Thanks for the help!
Regards Lukas
paolo bevilacqua
Hi, there are no licensing neither technical limitations. You can mix and match local and remote phones/teleworkers/IPCP as you whish within the maximum number of phones supported.
