UC520 - AA over SIP trunk - problem
arsa-2103
I have a problem with AA over SIP trunk. My SIP provider use g711alaw over SIP trunk.
My configuration is
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class sip-profiles 13
request ACK sdp-header Audio-Attribute modify "recvonly" "sendrecv"
response 200 sdp-header Audio-Attribute modify "recvonly" "sendrecv"
request REINVITE sdp-header Audio-Attribute modify "inactive" "sendonly"
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^...$/ /MY_number2/
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
dial-peer voice 3004 voip
description IN
service toroute5
session protocol sipv2
session target sip-server
incoming called-number MY_number1
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip profiles 13
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern ABC
b2bua
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711alaw
no vad
When I call My_number2, I get this error
SIP: (29) Attribute mid, level 1 instance 1 not found.
SIP: (29) Attribute ptime, level 1 instance 1 not found.
SIP: (30) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
000174: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/sipSPIStreamTypeAndDtmfRelay: No voice codec and dtmf-relay is not rtp-nte
000175: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/sipSPIDoAudioNegotiation: Media negotiation failed for m-line 1
000176: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/sipSPIDoMediaNegotiation:
no valid fax or audio streams
000177: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/sipSPICompareRespMediaInfo: Media Negotiation failed with no 18x Media
000178: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/ccsip_api_call_connect_media: Media Info Failure
000179: Feb  3 02:29:46.463: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
000180: Feb  3 02:29:46.463: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
000181: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container
000182: Feb  3 02:29:46.463: //30/4CF26B068037/SIP/Error/sipAddSipContainerToCallEntry: Unable to add passthru hdrs
                          to container
000183: Feb  3 02:29:46.475: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
000184: Feb  3 02:29:46.475: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
SIP: (31) Group (a= group line) attribute, level 65535 instance 1 not found.
000185: Feb  3 02:29:46.487: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length: Could not get Content-length
Can anybody help me with this problem?
Thanks!
5 Replies 5
Udit Mehrotra
Looks like media neotiation is failing on inbound pstn leg...
Collect
debug ccsip media
debug ccsip messages
debug voip ccapi default
Check if correct inbound dial-peer is matched... If that is correct, make sure that capabilities are matched.
Udit
Thanks for your reply.
Here's the log from UC520.
One important detail. My SIP provider routes based on the "To " header in which sents the DID number.
I solved the problem by following the instructions given in this post
https://www.myciscocommunity.com/thread/8245;jsessionid=5A71DADD8656E6375D366EC4E0080485.node0
I have tried to access the link but is not available anymore.
do you have the instructions?
regards
Open a new thread,so you can get help.
Please rate all useful posts
