UC540 using CCA: change outbound caller ID name.
Is this possible? I know I can set the caller id for the number, but I want to do this for the name and overwrite the telco's PRI default if possible.
Thank you!
George Thomas
Level 10
Level 10
Most telcos dont permit this.YOu could try adding "isdn outgoing display-ie: to the serial interface and see what happens.
Please rate useful posts.
