UCCX server not loading backup .tar file
simonmossman
Hi all
I have built a single server UCCX 5.0(2) and have backed up our working server and copied the .tar onto my new machine via usb. The problem is when I open the admin and choose the restore option and add the path I get an error complaining it cannot see any file...
Any ideas please?
Rob Huffman
Hi Simon,
Not my area of expertise (not sure if any are ) but I did see this
in a similar post;
we had a TAC case open.
In the path we had to put in:
Cheers!
Rob
Hey Rob
Thanks as ever for your input......amazing.....even when you are not in the comfort zone you still try and help..
I have actually tried the whole filename scenario with the following path syntax:
\\servername or ip\c$\Backupfilename.tar.It must be something trivial but......!!
I have even tried this with the local host address 127.0.0.1
Cheers
Simon
