09-27-2013 01:05 AM - edited 03-16-2019 07:34 PM
I have CM 4.1 with detailed CM traces enabled...
I have touble with hunt pilot/group...
Call should be routed PSTN - Gateway - Pilot number - Hunt group broadcast (number1,number2)
Where in trace I can found information how call really routed...
I found in
Subscr\c\Program Files\Cisco\Trace\SDL\CCM
file SDL002_100_000189
I can see what call routed from pstn to pilot number...
gpn.nd=92189xxx cgpnVM= cgpnVMCSS= cgpnVMP= dialedDig= cdPart= cdPat= cdpn.tn=4 cdpn.npi=1 cdpn.nd=1xx0
but I have not information about following call routing n hunt group)
Which file I should look to find this information?
Thank you very much...
Solved! Go to Solution.
09-27-2013 01:53 AM
you need SDI traces not SDL
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
09-28-2013 08:26 AM
SDI trace files are located under the following folder
C:\Program Files\Cisco\Trace\CCM
These are txt files and their name begins with ccm. You can sort them by date / time.
Manish
09-27-2013 01:53 AM
09-28-2013 12:10 AM
Yes, I know this...
But CM version is 4.1... It my first meet with 4.1
After collecting trace I can not find any SDI associated files...
traces configured exact as described
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Can any comment this problem?
09-28-2013 12:17 AM
Please make sure that you are looking for traces on the server to which the phones are registered. If the trace settings are correct then probably a server reboot is a good option for now.
Manish
09-28-2013 01:32 AM
Hello, Manish! Can you provide any comment's for this solution? You suspect what SDI trace not collected by software error, what should be resolved after server reboot?
Thank you very much!
09-28-2013 01:42 AM
The callmanager service is responsible for generating ccm traces, so if the traces are not being generated for some reason then a reboot should take care of the issue.
Manish
09-28-2013 05:45 AM
Manish, some question else...
CM trace generate several files and folders... in files/folder tree where i can expect found SDI file trace? and what the name should be? ABOut CM 4.1...
09-28-2013 08:26 AM
Manish
09-29-2013 11:03 PM
Hello Manish!
Thank you very much! I have found this files and now try to find information needed...
09-30-2013 01:10 AM
You can get some useful tips on reading SDI traces in windows callmanager versions from the following link
Manish
