04-05-2015 10:30 PM - edited 03-17-2019 02:33 AM
few phones getting UCM down error . How can i troubleshoot this issue
Below is the system status . I think memory usage is bit high , Is it normal ?
Host Name CM1
Date Sun Apr 05, 2015 14:43:10
Locale English (United States)
Product Version 7.1.5.34900-7
Platform Version 3.0.0.0-7
Uptime 14:43:11, up 52 day(s), 17:44, 0 users, load average: 00.24, 00.24, 00.20
CPU
Idle: 96.52% System: 02.99% User: 00.00%
IOWAIT: 00.00% IRQ: 00.50% Soft: 00.00% Intr/sec: 1063.00
Memory
Total: 2074700K
Free: 22272K
Used: 2052428K
Cached: 502200K
Shared: 0K
Buffers: 22192K
Disk
Total Free Used
active 12460452K 786588K 11547276K 92%
inactive 12460484K 890824K 11443068K 91%
logging 43358480K 3110216K 38045756K 87%
Host Name CM2
Date Sun Apr 05, 2015 14:47:26
Uptime 14:47:27, up 502 day(s), 05:50, 0 users, load average: 00.45, 00.34, 00.26
CPU
Idle: 97.51% System: 01.99% User: 00.50%
IOWAIT: 00.00% IRQ: 00.00% Soft: 00.00% Intr/sec: 1110.00
Memory
Total: 2074700K
Free: 25000K
Used: 2049700K
Cached: 625916K
Shared: 0K
Buffers: 10356K
Disk
Total Free Used
active 12460452K 808524K 11525340K 92%
inactive 12460484K 915704K 11418188K 91%
logging 43358480K 8576460K 32579512K 75%
04-06-2015 01:15 AM
As per
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/100982-ipcerror.html#P1
When you make calls, the Cisco IP Communicator/IP Phone displays this error message: CM Down Features Disabled.
This error message indicates that the call preservation feature is active because the application has lost its connection to CallManager.
The workaround for this or any other invocation of the call preservation feature is to hang up manually. If the phone does not return to normal on-hook behavior (all lines shown while idle, softkeys appropriately displayed, and responsive to user input), restart the Communicator application or the Cisco IP Phone.
If the above workaround did not fix the issue, it is recommended that you change the Station keepalive parameter to 60 or to its maximum allowed.
Note: Make sure that the IP phone can reach the Cisco Unified Communication manager. The IP reachablity issues can occur because of IP routing, VLANs, or multiple DHCP servers in the same network. Multiple DHCP servers can create problems if they assign a different subnet to the IP phone from which the IP phones cannot reach the CUCM server; this results in similar errors.
Manish
04-06-2015 01:18 AM
IDLE CPU is 90+ that means CPU is free..
Check connectivity between IP Phone and CUCM servers wise versa..
04-06-2015 07:45 AM
It look like a connectivity problem or the call manager service is down, Did you check both?
