07-11-2012 03:09 PM - edited 03-16-2019 12:09 PM
All,
Is there a clean way to force a caller to listen to the full greeting of a mailbox prior allowing further digits to be answered (as in the case of a 0 out transfer to the Operator) in Unity Connection 7.X?
The only way that I have known to be able to do this is to first transfer to a call handler with the greeting, ignore the caller input, and xfer out to the actual mailbox which doesn't scale well for multiple users.
Solved! Go to Solution.
07-11-2012 03:36 PM
That's the only option, as long as you don't disable caller input, they can try to digit something and Unity will see if it's tied to an action or try to transfer the call to such number.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-11-2012 03:36 PM
java
07-12-2012 07:27 AM
Yeah, that is what I had thought as well but I wanted to be sure I wasn't missing something.
Thanks for the reply.
