UDS Search on Jabber not working
Hi All,
I have a strange Problem on a Lab Environment with my Jabber for Windows Clients.
The Environment has no LDAP Server or any other Directory Source. There are no DNS SRVs configured. For Login I enter the Presence Server manually in the Jabber Client (in a Lab should not a big Task whith only some installations ;)).
So I want to use UDS for Contact search. I configured the Jabber XML file like this.
<Directory>
<DirectoryServerType>UDS</DirectoryServerType>
<UdsServer>IP-AddressofCUCM</UdsServer>
<PresenceDomain>Domain</PresenceDomain>
</Directory>
In the Logs I can see, that he Downloads the Jabber config XML file. So I assume, that he gets the Directory configuration. But in the Connection Status Jabber still wants to connect - via EDI - to a LDAP Server.
Can someone assist?
Thanks a lot!
DrMxxxxx
no DNS SRVs
no LDAP
2 Accepted Solutions
No, it DOES support UDS, we only dropped UDS support for a couple of releases back on the Jabber 9.x train due to performance issues as Jabber kept reaching the server without any need. It was supported again, I think with the 10.x releases, otherwise, that would mean that all MRA clients would not have UDS, and that's the only supported method over MRA
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_0/CJAB_BK_C04C09E7_00_cisco-jabber-110-planning-guide/CJAB_BK_C04C09E7_00_cisco-jabber-110-planning-guide_chapter_011.html
Does the Service Profile assigned to the client has the use UDS option checked??
java
if this helps, please rate
Ayodeji Okanlawon
Matthias,
It looks like i may have provided a wrong information..
Please try this jabber config file. Ensure you restart tftp server after uploading it. You may also do this via the service profile rather than using jabber config file..But this should work
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
<Directory>
</Directory>
</config>
Please rate all useful posts
13 Replies 13
Ayodeji Okanlawon
What jabber version are you running. Some do not support UDS and can only perform contact search via EDI only, that's why you are seeing this
umpf. Sorry, I forgot.
Versions:
Jabber 11.0
CUCM 10.5(2)
CUPS 10.5(2)
Kind regards,
DrM
Deleted
thanks a lot for that Information. I didn't read it, yet (RTFM, lol).
Is that also true for Jabber 11.1? I could not find the Deployment Guide for that Version.
Kind regards,
DrM
Deleted
java
Jamie,
even though the documentation says that Jabber 9.1.2 and above supports UDS, I know that jabber 9.6 doesnt support UDS. It may do UDS over MRA but it doesnt support UDS internally. This I discovered during my CCIE study.
This is what made me conclude this and I could be totally wrong
9.6 is one of those particular versions that dropped UDS support as I mentioned before, that version is also NOT supported for MRA, so it was no big deal it didn't have UDS. MRA requires 9.7+
Right now the downloads site doesn't even list anything below 9.7, probably to avoid issues with older releases
java
Hi, I tested UDS on Jabber 10.6 and was working although the doc is saying it won't.
However, if the windows machine is joined to domain, Jabber client will be smart enough to discover this and use EDI instead of UDS.
Try to configure UDS under User Management > User Settings > Service Profile and don't configure EDI.
thanks for the hint.
So, you mean, that I configure the UDS Directory like I would configure a LDAP Directory? Which Port do I have to use?
Kind regards,
DrM
It's actually not that Jabber is smart enough to choose one over the other, it's that the default directory mode is EDI, UDS HAS to be configured for it to work.
java
Ayodeji Okanlawon
Matthias,
<Directory>
</Directory>
</config>
Hi All,
many thanks for the answers I got on this question!
Ayodeji saw my mistake I made on the config file. Now it is working!
Thanks again.
Kind regards,
DrM
