UK E1 PRI
Rajesh Revuru
Level 4
Level 4
Hello:
When adding E1 PRI for UK using MGCP what would be the PRI protocol type?
2 Accepted Solutions
Rob Huffman
Hi Rajesh,
Hope all is well! You should check with the Service Provider but it may well be;
isdn switch-type primary-net5
Hope this helps!
Rob
I normally use PRI euro and never had any problems so far touch wood...
5 Replies 5
Rob Huffman
Hi Rajesh,
Hope this helps!
Rob
Rob:
All is good, thanks for the information,
for be the "PRI protocol type" in the CUCM GUI page. Currently have following options and i guess it would be PRI-EURO
1. PRI EURO
2. PRI Australian
Rob Huffman
Hi Rajesh,
Sorry for the delay, I missed your reply completely :(
"PRI - EURO" should be just fine as nicely stated by Bruce. (+5 points for your good work here Bruce)
Take care buddy!
Rob
Rob & Bruce:
Thanks for your input.
