03-15-2018 02:52 AM - edited 03-18-2019 12:24 PM
It appears I am unable to assign users under user management=>assign presence users.
When I try, I get the error "Update failed. Cannot assign a user to a server that is not in a valid state".
I've tried both servers and both of them give the same error. Is there any service I can restart to fix this?
Screen shot attached.
Solved! Go to Solution.
03-15-2018 03:33 AM
Ideally, the Server State should be NORMAL.
Is IMP Second Node reachable and services UP ? If yes, u can click on "FallBACK "to restore .
regds,
aman
03-15-2018 03:23 AM
Can u check what is the user status under User Management --End Users?
Is it showing "Enabled Local User" or "Active LDAP synchronised user "?
regds,
aman
03-15-2018 03:26 AM
They are active LDAP users.
Also I have noticed under the presence redundancy groups that the pub is running in backup mode, reason, peer down. And the Sub is running in Failed over mode, reason, Initialization.
There is the option next to the sub to "fallback"
03-15-2018 03:33 AM
regds,
aman
02-08-2023 10:54 AM
This was very helpful.
09-24-2018 11:03 PM
Go to the CUCM System > Presence Redundancy Groups
Click find and choose the correct group just uncheck "Enable High availability" checkbox. You should be able to assign the user then.
Once User is assigned you need to check the "Enable High availability" again.
Please rate if it helps....:)
02-21-2019 10:07 PM
02-22-2019 01:02 AM
No the correct answer was to "Fallback" the redundancy group.
02-22-2019 03:34 AM - edited 02-22-2019 03:35 AM
Thanks @sandeep_yadav07 ,
02-22-2019 03:47 AM
Incorrect answer for this post.
06-19-2020 11:35 AM
