07-11-2013 01:09 AM - edited 03-16-2019 06:19 PM
I have been trying to remove all the data relating to one of our closed offices. I have managed to get rid of almost all of it except for 2 calling search spaces. When I try to remove them I get the following message:
Error occurred. One or more record did not get deleted. The pkid column in the callingsearchspace table in the database is being referenced from another table. Please check the dependency records, remove the reference, and then try the delete again. | |
27 records found |
I have checked the dependency records for both and despite the indication of there being 27 records, they are both empty.
Is there any other way to search for where these may be referencing?
Running call manager 6.1.4
Steve
07-11-2013 04:02 AM
07-11-2013 06:10 AM
Another area you may find the CSS being referenced which does not show in dependency records is the BAT templates.
HTH,
Chris
07-16-2013 04:11 AM
I have this issue too.
I ran the sql query against the two options below and it returns nothing.
fkCallingSearchSpace_CFA (Forward All) fkCallingSearchSpace_SCFA (Secondary Calling Search Space for Forward All)
I suspect that there is a phone with the calling search space that I am trying to deleted set on the unregistered call forward option on the device profile.
Is there any other option I can run this command against.
This is on Call Manager 7.1.5b
Anthony.
07-16-2013 06:44 AM
Hi Anthony,
Can u refer this URL and then, run the SQL query.
http://www.ucguerrilla.com/2012/04/cucm-sql-queries-listing-call-forward.html
regds,
aman
07-17-2013 02:46 AM
Hi Aman,
Thanks for this url. The command below worked for two of my CSS but I still have one CSS left. I am almost sure that this CSS is referenced in one of these settings:
Forward Busy Internal
Forward Busy External
Forward No Answer Internal
Forward No Answer External
Forward No Coverage Internal
Forward No Coverage External
Forward on CTI Failure
Forward No Unregistered Internal
Forward No Unregistered External
run sql select n.dnorpattern, css1.name as primaryCSS, css2.name as secondaryCSS from numplan as n inner join callforwarddynamic as cdn on cdn.fknumplan=n.pkid left join callingsearchspace as css1 on cdn.fkcallingsearchspace_cfa=css1.pkid left join callingsearchspace as css2 on cdn.fkcallingsearchspace_scfa=css2.pkid where n.tkcfacssactivationpolicy = 1 or n.tkcfacssactivationpolicy = 0 order by n.dnorpattern
Anthony.
07-17-2013 05:23 AM
Hi Anthony,
I was just thinking if u could use the below query to list all CSS .from there, u can get partitions
http://www.ucguerrilla.com/2012/04/cucm-sql-query-series-installment-6.html
Now use this query to list all DNs assoociated with Partition.
http://www.ucguerrilla.com/2012/03/cucm-sql-queries-installment-3.html
redgs,
aman
07-17-2013 06:50 AM
Hi Aman,
When I run the first query, I cannot see the CSS I am trying to delete in the output.
Is there a SQL query against the other forwarding types "Forward No Coverage" like there is for call forward all "fkCallingSearchSpace_CFA"
Anthony.
07-17-2013 07:27 AM
Hi Anthony,
No idea beyond this.
regds,
aman
