Unable to Dial International Calls from the USA
smh1218
I am having difficulties getting International Calls to go through. Does anyone have any clue to what would be preventing me from making those calls?
RtR Config:
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
vlan internal allocation policy ascending
isdn switch-type primary-ni
voice-port 0/2/0:23
bearer-cap Speech
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name 976
dial-peer cor list call-international
member international
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 6 pots
description Outgoing Calls
destination-pattern 9T
port 0/2/0:23
dial-peer voice 5 pots
description International
destination-pattern 9011T
port 0/2/0:23
forward-digits 15
20 Replies 20
I want to thank everybody for all of the help on this issue. The problem is resolved, I set the config to:
interface Serial0/2/0:23
no ip address
isdn incoming-voice voice
isdn map address ^011.* plan unknown type international
i have a problem making international calls
the carrier ATT(Megacom) says I am sending International and it should be national and they dont want to see the 011
how do i strip the 011...CM 4.1 PRI MGCP
thanks
Colum
Here's what you do:
Create a route filter and call it international. Set a clause in the route filter stating international-access == exists. Apply this route filter to your route pattern that you are using for international calls. On your route pattern, digit strip is PreDot. Im assuming your route pattern is 9.@. Then make a route group, lets call it international, and add the PRI's that you need to add. Then make a route list also called international, and add your international route group to the route list. On the route list configuration, you are going to use the discard digits option called "PreDot IntlAccess IntlDirect Dial. Then bounce mgcp and it should send calls to the PSTN marked "national" and strip the 011.
Also, on the PRI's in question, set all the numbering types and plans to "Cisco CallManager".
Hope that helped, if so please rate.
Colum,
Here's one way to accomplish this. Make your route pattern in CCM (Route Plan > Route/Hunt > Route Pattern) 9011.! and make Discard Digits under Called Party Transformations PreDot. Also, in your gateway/endpoint configuration (Device > Gateway > Choose your gateway > Choose your endpoint), make the numbering type National.
Hope this helps.
Brandon
The strip seems to be working but still says type international...where could it be getting it from
Called Party Number i = 0x91, '4401614746081'
Plan:ISDN, Type:International
the type under Device > Gateway > Choose your gateway > Choose your endpoint is National
Try changing it all to Cisco CallManager and see if that works.
