Unable to load route plan report in CUCM
praneshkumarz
CUCM System version: 9.1.2.13058-1
Error detail:
Unmapped Exception The attempted action was a violation of security protocols and will not be allowed. Please try another action
This occurs even when logged into the administrator account.
Already tried different browsers and removing the cache as well. happening only when opening Route plan report. Also don’t have multiple tabs opened for the same node/site. tried different machine also but no luck
Happening with both Publisher and subscriber
tried restarting tomcat service as well as server restart, but no luck
Related Bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq53672/?referring_site=bugquickviewredir
Known Affected Releases:
10.5(1.98000.226)
10.5(1.98000.230)
Will this be effective to 9.1.2.13058-1 aswell?
Manish Gogna
Hi Pranesh,
The bug specific for this issue is the following one
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur13329/?reffering_site=dumpcr
Bug Search Bug Search - Cisco Systems
route plan report throws unmapped exception error
CSCur13329
Description
Symptom:
Conditions:
First seen in CUCM 9.1.2.13058-1
Workaround:
none
Further Problem Description:
Caused by CSCup74290 in 8.6(2) & 9.1(2). Also requires CSCur55465 in 8.6(2) & 9.1(2)
Check the read me for the latest 9.1.2 SU version on cisco.com and upgrade to one with the fix for the above bug.
Manish
Thank you Manish..
You can upgrade to 9.1.2 SU5 , download from the following link
https://software.cisco.com/download/release.html?mdfid=284510097&flowid=77894&softwareid=282074295&release=9.1(2)SU5&relind=AVAILABLE&rellifecycle=&reltype=latest
The bug is fixed as per the read me file for the same
http://www.cisco.com/web/software/282074295/132156/cucm-readme-912su5.pdf
Manish
