Unable to login to Extension Mobility
alalli
Level 2
Level 2
Hi All,
I am setting up extension mobility using Cisco IP Communicator phones and CUCM 8.6 in a virtual environment.
The CIPC phone shows extension mobility when I select the services button, but I am not able to select the service nor log on.
I was wondering if anyone else has seen this sort of behavior and can tell me where to look to resolve the issue.
Many thanks
Amanda
yahsiel2004
Level 7
Level 7
Do you get an error code?
Yosh
HTH Regards, Yosh
admincoco
Check the user Password.
Check the association Device profile > End User
Check if something is bloked on the network (if there is a Firewall between your CIPC and your CUCM). This last action fixed my issue. Some ports was denied
Hi All,
I have sorted out the issue with Extension mobility.
At first I looked at the windows based firewalls on the test PCs, but that did not affect the outcome.
The users did not receive the login prompt when they selected the services button.
In the end,  I restarted my CUCM server and that resolved the problem.
Had this been a production network and not a lab, I might not have had the luxury of restarting the server.
If I had it to do over again, I would have started off restarting only the EM service.
Many thanks for the suggestions of looking for the errors and checking the firewalls though.
Best Regards
Amanda Lalli-Cafini
Hi Amanda
Are you using HTTP or HTTPS for EM service? Do you get an error code?
Remember as CIPC do not support HTTPS. It only suports HTTP. Bug ID:CSCtx18810
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
