01-18-2012 07:23 AM - edited 03-16-2019 09:04 AM
Hi Friends,
I am experiencing the following issues with cisco 7945.
I have successfully configured telephony service on Cisco 2921 router with Ios
c2900-universalk9-mz.SPA.151-4.M3.bin i and I can able to make intra site calls using the Cisco 7945, but failed to make inter site calls. I have re-checked the dial-peer configuration, but it seems that correct.
Site-1 Router
dial-peer voice 214 voip
description CALL TO SITE2
destination-pattern 1077..
session target ipv4:10.77.13.254
Site-2 Router
description CALL TO SITE1
destination-pattern 1055..
session target ipv4:10.55.13.254
The second issue is with the "Cisco video advantage" on the other two sites, I have installed “video advantage” in two intra-site XP-machines, and can make audio calls, but not able to perform the video chat. I have enabled the video on ip phone, but on task bar, I there is an exclamatory mark on the video advantage icon and showing that the link between the phone and the camera has broken.
Please advice...
Ranjith K.R
Bangalore
01-18-2012 08:35 AM
Ranjith,
Issue 1: What happens when you make inter site calls and what is an example extension number being called?
Issue 2: Did you enable the Span to PC port on the phones?
01-18-2012 08:35 AM
Please post configs of both routers.
Chris
01-18-2012 09:19 AM
Hi Yasheel, Chris,
Yes Span to PC port is enabled.
I have made the numbers as
site-1 ip ph 1--no : 107710,
site-1 ip ph 2--no : 107711
site-2 ip ph 1--no : 105510,
site-2 ip ph 2--no : 105511
site-3 ip ph 1--no : 106610,
site-3 ip ph 2--no : 106611
I can make calls from 107710 to 107711, also I can able to call to the third site from 1 and vice versa, without any issues...
but can not make to 105510 & 105511.
Ranjith
01-18-2012 09:25 AM
Are these SCCP or SIP phones?
To get started can you post "debug voice dialpeer" from both routers when making a call?
Chris
01-19-2012 08:05 AM
Hi Chris, Yasheel,
Phones are SCCP. I have done the "debug dial peer" on both the sites and found that the issue was with the multiple tag found on the site -2.Removed the tag and the first Issue got resolved.
Unfortunately the issue with the “video advantage” still persists.
Ranjith.
01-19-2012 08:12 AM
Ranjith,
Another thing to check would be the firewalls on the XP machines and that the phones have the videos icon on the bottom right hand corner of the screen.
Yosh
01-20-2012 05:42 AM
Yasheel,
I have enabled the video on ip phone as I given the details below.
ephone 1
device-security-mode none
video
mac-address E8BD.7006.8971
ephone-template 1
codec ilbc
type 7945
keep-conference endcall
button 1:1
I have also re-checked by disabling the antivirus and firewall on pc, but stil the issue persists.
Ranjith..
01-20-2012 05:59 AM
Can you confirm that you have set up video basics under telephony service
telephony-service
video
maximum bit-rate 256
service phone videoCapability 1
Alex
01-20-2012 06:25 AM
Alex,
I am unable to configure "video" under the telephony service, the command is not recognized.
RT(config-telephony)#vide?
% Unrecognized command
Ranjith
01-20-2012 06:53 AM
Looking at the VIDEO section in the CME Admin Guide.
Configuring VIDEO is a prerequisite
This works for me on 12.4.24T2
May be you are hiiting an IOS bug
Time to raise a TAC
Alex
01-21-2012 07:18 AM
Alex,
Here is the video debug
Jan 21 05:51:26.331: ephone-1[0/6][SEPxxxx70061175]:SkinnyGetMultiMediaCapabilities: dn: 1, chan: 1
Jan 21 05:51:26.331: ephone-1[0/6]:video_caps_count is zero
Jan 21 05:51:26.379: ephone-1[0/6][SEPxxxx70061175]:SkinnyGetMultiMediaCapabilities: dn: 1, chan: 1
Jan 21 05:51:26.379: ephone-1[0/6]:video_caps_count is zero
Jan 21 05:51:36.535: ephone-1[0/6][SEPxxxx70061175]:checkToOpenMultiMedia: dn=1, chan=1
Jan 21 05:51:36.535: ephone-1[0/6][SEPxxxx70061175]:skinnyDP[1].s2s = 0
Jan 21 05:51:36.535: ephone-1[0/6]:s2s is not set for video.
Ranjith,
02-08-2012 11:42 PM
Hi Friends,
The issue was due to the symmentec end point protection firewall blocking the cisco ip phones. I have contacted them and they have told me that it is a known issue and provided the solution has to exclude the ip phone mac addresses in the ep firewall. Done the same and the issue got resolved.
Ranjith K.R
Bangalore
03-10-2016 04:14 AM
Hi!
I have same problems. Please can you help me ? What is ep firewall ? Where do this configuration ? On CME ?
