07-19-2016 12:46 AM - edited 03-17-2019 07:34 AM
Dear All,
We are unable to make external calls over FXO lines. When digit is pressed we are hearing noise and cannot dial further. What could be the problem.
07-19-2016 02:08 AM
Is the call being made from phones registered to cucm or CME and what is the exact call flow? Do you have the output of the following from the gateway for a test call
show voice port summ
debug voice ccapi inout
and the running config from the gateway.
Manish
07-19-2016 03:03 AM
Hello Manish,
Phones are registered to CME and I have 6 FXO lines. I am hearing a crackling noise.
Phone à CME à FXO à PSTN
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxo-ls up dorm idle on-hook y
0/1/2 -- fxo-ls up dorm idle on-hook y
0/1/3 -- fxo-ls up dorm idle on-hook y
0/2/1 -- fxo-ls up dorm idle on-hook y
0/2/3 -- fxo-ls up dorm idle on-hook y
0/3/0 -- fxo-ls up dorm idle on-hook y
07-19-2016 03:09 AM
Do you means the call is established but there is a voice quality issue? Do the internal calls between phones registered to CME work fine?
Manish
07-19-2016 05:11 AM
Do you mean the call is established but there is a voice quality issue?
No. Calling is not getting established.
Yes.
Now calling to mobile numbers is working fine (only mobile numbers not landline)
Let me explain.
Following number is a local landline number 96602808, and when the user dials the number there is no progress tone (meaning no further indication). Please find the debug ccapi output.
Calling Number: 81504
Called Number: 96510666.
07-19-2016 05:28 AM
From the debugs the call is going out via dialpeer 4 and it does connect but immediately disconnects with cause code 16 which is normal, i would say check with your Telco about this unless someone can find anything diff / additional in the debugs.
Manish
07-19-2016 05:15 AM
