unable to obtain additional ringtones from server 7841 IP Phone
jaheshkhan
Level 5
Level 5
Our client facing problem with ringtone for IP Phones as below:
Customer unable to play the ringtones other than Chirp 1 & 2.
Customer able to see the other ring tones, when try to access they get error message 'unable to obtain additional ringtones from server'
I think they are hitting the bug
https://quickview.cloudapps.cisco.com/quickview/bug/CSCva82202
Their CUCM version is 11.5.1.10000-6
Is there any workaround at the moment? they want to change the ringtone or add new ringtone. but only 2 ringtone its showing.
20 Replies 20
I think your file is way to big. The documentation says that it should be in-between 240 and 16080. Please try with these files attached.
But the video shows a bigger file, so I'm not sure on this.
Response Signature
Yeah. I was wondering why in the video it used long file. I selected the same 72720 samples...
Let me check this file
Thank
kindly note the file which you provided  also didnt work.
Then I'm out of ideas. Recommend you to reach out to TAC to get their help on this.
Response Signature
Unfortunately no chance of TAC at the moment.
jaheshkhan
Level 5
Level 5
Atlast i found the issue..
for 7841 and 8841 the file should be Ringlist-wb.xml
I was trying on Ringlist.xml instead of Ringlist-wb.xml
So cop there is no issue. its working fine..
