Unable to receive fax from one number using VG224
Dinesh Rathi
I am facing an issue where I have a some fax machine connected to a VG224 gateway and it is not able to receive fax from one number. Some facts:
1. All other fax machines can send and receive faxes fine (including the number from which the fax is not received)
2.Using SCCP on VG224
3.Getting Fax tone on the affected fax machine.
4.Fax can be sent to the affected number.
5.Configuration on the port where the issue is occuring is same as for the other ports.
Please suggest,
Dinesh
yahsiel2004
Level 7
Level 7
Have you verified that you can receive faxes on the fax machine in question, from a pots line?
Yosh
HTH Regards, Yosh
Dinesh Rathi
Yes, I did and it works.
Can you post the config?
Yosh
HTH Regards, Yosh
