Unable to reset a Cisco 8811 phone to factory default
Dear Cisco team,
I want to reset a Cisco 8811 phone to factory defaults and i am doing the following steps but it is not working:
Reset the Phone to the Factory Settings from the Phone Keypad
You can reset the phone to the factory settings. The reset clears all the phone parameters.
Procedure
Step 1
Remove power from the phone in one of these ways:
·         Unplug the power adapter.
·         Unplug the LAN cable.
Step 2
Wait 5 seconds.
Step 3
Press and hold # and plug the phone back in.
Step 4
When the Headset and Speaker buttons are lit, release # and enter the following key sequence:
123456789*0#
The light for the Headset button turns off after you press the 1 key. After you enter the key sequence, the Mute button lights.
Caution
Do not power down the phone until it completes the factory reset process, and the main screen appears.
The phone resets.
7 Replies 7
Thanks Mohammed but even after doing these steps the phone is again booting up without going to factory defaults.
Vik.
What firmware are you using? Was it registered with 3rd party before?
HARIS_HUSSAIN
1) What happens when you enter the sequence 123456789*0# Does the Phone reset?
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Dear Hairs,
After i press the keys in sequence then instead of Phone going to Factory Defaults; it again boots up.
Vik.
You need to provide more information about what you expect to happen, and what is happening.
"It boots up" doesn't explain anything, the phone is supposed to boot up after being reset to default.
If Phone is connected to the Network from where cucm is accessible then after reset phone will again download the configuration and firmware from the CUCM and load the same old configuration.
Remove the phone configuration from CUCM and reset to factory default.
Haris
