Understanding using router to simulate PSTN
eigrpy
Level 4
Level 4
Hi Anyone can send a link to explain how to use router to simulate PSTN? I got some configuration on router to simulate PSTN. but it is difficult to understand them. Thank you
Please be more specific.
http://www.networkworld.com/article/2346450/cisco-subnet/home-lab--pstn-simulation-.html
Thanks for your reply. The below is some of config of PSTN in router and I only know function of some of config. Why do they act as PSTN? Can we think this simulated PSTN is configuration like for an analog phone?
I want to know what are specific required components for PSTN function configuration and their functions.
voice service voip
 no ip address trusted authenticate
  bind control source-interface FastEthernet0/0.192
  bind media source-interface FastEthernet0/0.192
  registrar server
voice register global
 mode cme
 source-address 192.168.1.254 port 5060
 timeouts interdigit 5
 max-dn 9
 max-pool 9
 load 9951 sip9951.9-1-1SR1
 time-format 24
 tftp-path flash:
 create profile sync 0002518403107605
 ntp-server 157.26.1.250 mode unicast
 camera
 video
voice register dn  3
 number 911
voice register dn  5
 number 999
voice register pool  1
 id mac 3CCE.7359.3308
 type 9951
 number 1 dn 1
 number 2 dn 2
no this is config is for your SIP endpoints,PSTN is nothing connecting you to outside world.If you putting in just for lab purpose you can SIP/PRI/FXO line configure between or bridging two lines
Cisco Router/VGW are capable doing  inter-operability if you have some FXS line or SCCP or SIP endpoint etc and proper destined/voice routing it suppose to reach to your number which you have configure here.
Br, Nadeem Please rate all useful post.
Deepak Rawat
https://learningnetwork.cisco.com/thread/10949
Deepak
