05-18-2016 11:37 AM - edited 03-17-2019 06:57 AM
We have recently ran into an ambiguity with Cisco about supported hardware platforms for Unity Connection.
Plan was to migrate CUC 8.6 on MCS to 10.5 on UCS E140S. While, there are conflicting options from Cisco whether E140S supports CUC 10.5 or not.
While, doc wiki says it does support 8.x, 9.x, 10.x and even 11.x
Cisco Unity Connection on UCSE
Whereas, Cisco Unity Connection Supported Platforms List for 8.x, 10.x and 11.x doesn't have it listed. Only 9.x has E140S under supported hardware.
Unity Connection 9.x Supported hardware list
Unity Connection 10.x Supported hardware list
TAC right away rejected the case initially, until we shared doc Wiki details. Now, we wait for an answer.
Did anybody ran into similar situation or tests in lab?
Sami
Solved! Go to Solution.
05-19-2016 10:40 PM
It is supported subject to the following config:
Manish
05-19-2016 10:40 PM
Manish
