06-07-2012 01:52 PM - edited 03-16-2019 11:33 AM
Hello guys!
Im kind of confused about the scheduling of System Call Handlers. I shceduled a Call Handler but is still active after the shcedule ended. Can you shed some light on how to properly shedule a Call Handler and turn the after hours call handler? Thanks in advanced!
Solved! Go to Solution.
06-07-2012 02:14 PM
I have attached a document of a callhandler set up with schedule..
These are the steps you need
1. configure your schedule
2. assign your schedule to your callhandler
3. enable the closed greeting to your callhandler...you can set greeting to blank if you dont want to play any greeting
4. set after greeting action to go to your after hours callhandler
The attached document shows a callhandler with schedule and closed greetings enabled..
Please rate useful posts
"I am complete in God, God completes me"
06-07-2012 02:14 PM
06-08-2012 06:40 AM
Excellent! Thanks a lot for the docunment and information.
