Resolved! CUBE - Skype SIP Trunk - Video
I have configured the CUBE->CUCM voice calls inbound and outbound.Has anyone been able to get Video Calling working over a SIP Trunk? I am using a 8945 as the video inpoint.Thanks,Edwin
I am upgrading from CUCM 6.1.5 in a VM Workstation Lab environment in anticipation of receiving my new hardware. I am trying to download 8.6(2)SU1 from Cisco and it says it should be 4.4gb but I only get 437mb at the completion of the download.. Is t...
Hi everyone,I have created APP Users and provided readonly acess to them.now i want give permission to them to change their account password.plesae letme know which role will provide these kind of access.
All,I'm having problems synchronizing with Open LDAP users. Actually I can sync a maximum of 250 users.Is there any configuration or limitation that causes this?Thank you!Luciane de Medeiros
Dears,I have installed VXC and i have no seen any deference between having an IPC instead of having VXC. As i understood, I must install VXC(which installs IPC) on my physical PC and CUCP on VMware host (Virtualized Client). So when I make a call the...
Hello,Is there a way to trigger a shutown of the CM server from an external source. Any information would be appreciated.Thanks,
I'm having some troubles and need to enable the field Setup non-ISDN Progress Indicator IE Enable into the MGCP GW configuration. This field is disabled and I cannot flag that.How I can flag that field?
Hi all,one of our customer has complained about not working (unregistered) 7936 conference station.He has sent me the IP address of the conference station, so I was able to to check its setting.I have found, that its MAC address has changed from orig...
Hi all, I am trying to figure out if it is possible to configure call-foward no answer while in SRST mode to the PSTN. Essentially, my offices call-forward to an answering service at 5pm each night for afterhours phone coverage. If we have a networ...
Hello.I have an issue with an ipccx server that is restarting continuosly, and does not allow the IPCCx application to run.We have replaced the memory and the system board but the problem remains.Does any one face something like th...
Hello,I have a question about SBC (H323<->SIP) session licensing specifically on the ASRs.My question is when the call is being processed thru the SBC but not answered on the far end, like the far end did not pick up the call yet, and only ringing.D...
With Randy WuWelcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn from Cisco expert Randy Wu best practices on how to configure and troubleshoot Cisco UBE for the public switched telephone network Sessi...
We have 7942 IP phones and a UC560 router. We are trying to connect the Plantronics Savi W730 Headset system. Plantronics told me that we need to turn on the "off hook" feature in the phone before it will work. Anybody know how to do this?
Hi all,Is there a limitation on the search results of the Cisco Cius Corporate Directory?I can only see 50 results. It's working fine with another models.What is the Cisco UC manager account? i am trying to configure this account ( putting owner the ...
Subject | Author | Posted |
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM |
User | Count |
5 | |
3 | |
1 | |
1 | |
1 |
