Unity Connection 8.6 Not Showing Product Deployment Selection
Carl Messer
I am attempting to install a new Unity Connection cluster and when I boot to the DVD supplied I am not being prompted to select from Unity/CUCM or CUCM Business edition, it boots straight into CUCM without giving me any options in the product deployment selection screen.
The message "The Cisco Unified Communications Manager product swuite will be installed"
Has anyone experienced this before and has a solution?
My experience has always been with Unity running on a Windows OS.
Carl Messer
Aaron Harrison
Hi Carl
Unity, CUCm and CUCMBE are all supplied on the same DVD. If you don't get options, it's because your server does not meet the required specification.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Hi Carl
Aaron
Thanks Aaron, it appears my partner has sent a server that does have enough resources to run Unity.
Thanks for your prompt reply.
Carl
No problem!
I think it's probably the increased RAM requirement on 8.6 that caught them out...
Aaron Harrison
Principal Engineer at Logicalis UK
I found this post and was very useful to me, so I will add that if you are experiencing this problem while attempting to use an .ISO with VMware, you must assign at least 4GB RAM for Unity Connection to be available. Check the supported platforms section for the documentation guide. For example:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
