Unity Connection 8.6 - SQL query to list account creation time
jon-lewis
Hello everyone.
My customer has asked for a listing of every user in their Unity Connection 8.6 system and the date that user account was created.  I'm thinking that using the subscriber alias and their mailbox creation time should do it.
While I'm not sure of the syntax, its been suggested that a SQL query might be able to search the user records and return for each user, the voicemail subscriber alias and the mailbox creation timestamp. This sounds exactly right but but I've no idea how to construct the required SQL query in a command form that I can paste into Unity Connection.
I had a search before posting but didn't really find anything relevant to this fairly obscure request. Can anyone suggests the commands that may be used from CLI on the Unity Connection server to accomplish this, please?
Thanks in advance.
Jonathan
Rob Huffman
Hi Jonathan,
You could use this great tool from the Unity Tools suite
Cisco User Data Dump
These are pre-canned Field definitions;
Date of user creation. The date the user was added to the Unity Connection system
Alias.
http://ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm#_Toc359835396
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Rob Huffman
Hi Jonathan,
Alias.
Cheers!
Rob
- OneRepublic
Bingo!
Many thanks Rob.
Jonathan
Rob Huffman
Hi Jonathan,
You are most welcome my friend! These are some of the best
Cisco Tools available to be sure
Cheers!
Rob
- OneRepublic
