Unity Connection 8.6 to 10.5 upgrade error message
mightyking
Level 6
Level 6
Hi Everyone,
I am upgrading Unity Connection from version 8.6 to 10.5.2.13901 and receiving the following error message:
An Unknow error occurred while accessing the upgrade file.
I tried using different options including SFTP or Local DVD/CD but no luck.
I tried to isolate the file into a folder which only contains the upgrade file . I also changed the OS Secure to Premissive again but none of the options worked. Here's the out put of the show version active:
admin:show ver
admin:show version ac
admin:show version active
Active Master Version: 8.6.2.21900-5
Active Version Installed Software Options:
ciscocm.version3-keys.cop
ciscocm.cuc_upgrade_10.5.2su3.cop
admin:
Would you please share your experience.
MK
Aman Soi
Hi MK,
Just a thought:
What is the vCPU being used for UCXN 10.5?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/release/notes/10_5_2cucrn.html#39225
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/supported_platforms/10xcucspl.pdf
regds,
aman
Hi Guys, thank you for taking the time and replying.
Please find attached the install log file.
Aman,
Here's the info regarding the vCPU being used.
VMware Installation:
        2 vCPU: Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz
        Disk 1: 200GB
        6144 Mbytes RAM
MK
Which node fails to upgrade? Is it the Publisher or Subscriber node?
Is the Database Replication active?
The following error can be seen in the install logs:
07/12/2016 09:37:21 component_install|Execute "/common/refresh_upgrade/Cisco/connection/scripts/cuc-export RU Export 10.5.2.13901-2 8.6.2.21900-5 /common/component/connection /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
07/12/2016 09:41:48 component_install|Writing unity connection into /common/log/install/component_failed.xml file.|<LVL::Info>
07/12/2016 09:41:48 component_install|/common/log/install/component_failed.xml created : 0|<LVL::Info>
07/12/2016 09:41:48 component_install|(CAPTURE) Launching export|<LVL::Debug>
07/12/2016 09:41:48 component_install|(CAPTURE) Database replication is not active.|<LVL::Debug>
07/12/2016 09:41:48 component_install|(CAPTURE) |<LVL::Debug>
07/12/2016 09:41:48 component_install|File:/common/download/10.5.2.13901-2/Cisco/bin/component_install:874, Function: execute_shell_cmd(), /common/refresh_upgrade/Cisco/connection/scripts/cuc-export RU Export 10.5.2.13901-2 8.6.2.21900-5 /common/component/connection /usr/local/cm/ /common/log/install/capture.txt failed (1)|<LVL::Error>
07/12/2016 09:41:48 refresh_upgrade|Final exit processing with result 1|<LVL::Info>
Provide the outputs for the following:
- show cuc cluster status
- utils dbreplication runtimestate
- utils ntp status
In addition to this, you can reboot this node, attempt the upgrade again and in case it fails then please provide the complete upgrade logs via RTMT.
Atul Gaba
Can you provide the insall logs for a failed upgrade.
-Atul
