01-24-2013 12:38 PM - edited 03-16-2019 03:21 PM
Hello All. Is there a way to add rings before a system call handler picks up in unity connection? We are running version 8.6 and when a caller dials the call handler extension it immediately starts playing the greeting without the caller hearing rings.
Thanks!
Solved! Go to Solution.
01-25-2013 11:45 AM
Hey Phil,
Well I'm stumped (no surprise )
But I did come up with a work around if you
are interested. I am attaching a ringback.wav
file that I used on a front end call handler greeting
(using reprompt caller = 3 time between reprompts = 2)
I then used the after greeting action to route to the required
call handler.
So I called 8567 which is now call handler #1 it plays the 4 rings
and then transfers (directly to greeting) to the actual informational
call handler @ 6198 using the after greeting action on 8567.
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
01-24-2013 12:49 PM
Hi Phil,
I've done this in the past using a CTI -RP in CUCM with the
Call Handler extension/DN and leveraging the Forward No Answer
rather than using Forward All (on the CTI-RP DN config page)
Cheers!
Rob
-Springsteen
01-24-2013 01:14 PM
Thanks for the response Rob. For some reason the CTI-RP is not registering with unity connection. I notice that I have to have Forward Unregistered Internal/External checked for unity to pick the call up. It just rings busy if I have forward no answer by itself checked. I assume the no answer ring duration only applies to the forward no answer.
01-24-2013 02:04 PM
Hi Phil,
You won't see the CTI-RP's as registered so that part is cool. I would check
the CSS(s) for the forwarding anomolies. You should be able to use Forward all
and Forward No Answer without issue.
Cheers!
Rob
-Springsteen
01-24-2013 02:36 PM
Ok, for some reason the forward no answer just gives a busy. I checked the CSS for the No Answer and it is using the same one that my other DN's and Forward Unregistered are using. The only way I can get it to route to unity is with the Forward unregistered checkboxes checked.
01-25-2013 06:17 AM
Hi Phil,
When you get a window, can you try deleting the CTI-RP
and deleting the DN from the Unassigned DN's via the Route Plan
Report page and then rebuilding the CTI-RP. Make sure to pay special
attention to the Partition/CSS and then retest.
I have looked for any bugs related to this type of issue and have
come up empty. Are both Connection and CUCM @ 8.6?
Cheers!
Rob
-Springsteen
01-25-2013 07:10 AM
I will give that a try and see what happens.
Yes, both CUCM and UC are 8.6. This is the Business Edition so both are on the same server.
01-25-2013 07:26 AM
I just did delete the CTI-RP and unassigned DN but still have the same issue. As soon as I check Forward Unregistered the route point will go to the call handler and greeting.
01-25-2013 07:35 AM
Hi Phil,
Maybe the CTI-RP works differently in Business Edition?? I
can't vefiry this as we don't run it
In BE can you go to Call Routing> Directory Number and create the DN
directly? It's another method to route calls where you might be able to
use the forward no answer. Or create a "dummy" phone with the DN
and use the forward no answer.
Just trying to think of different options.
Cheers!
Rob
-Springsteen
01-25-2013 07:54 AM
Hello Rob,
I believe the only difference between BE and CM is that I cannot have a subscriber with BE edition. Other than that the software I believe is the same.
I did orginially create the DN like you mentioned above and it still requires the Forward Unregistered to be checked. Also, I tried to create the "dummy phone" and it just rings busy too.
Thanks for all of the suggestions.
01-25-2013 08:35 AM
Hi Phil,
Something doesn't add up here at all. These are all valid
ways to route calls via forward no answer forward all etc.
It's got to be a CSS/Partition issue I far as I can tell. I'm stumped
other than that my friend
Does your phone Forward No Answer to voicemail work? If so, can
you try with the exact same CSS/Partition set on the CTI-RP forward
settings.
Cheers!
Rob
-Springsteen
01-25-2013 09:42 AM
Hello Rob,
Yes, my phone does work with forward no answer and is in the same partition/CSS as the CTI-RP and DN that I created. The only thing that I notice is that the status of the route point is unknown which I believe you said is normal. However, since the DN/CTI-RP is not registered to anything would this maybe force the DN to use Forward Unregistered and bypass the Forward No Answer? I would also assume since the call handler picks up when I have the Forward Unregistered checked that the CSS/Partition must be correct. This is the same one that I am using on the no answer option.
Thanks!
01-25-2013 11:45 AM
Hey Phil,
call handler.
Cheers!
Rob
-Springsteen
01-25-2013 12:08 PM
Maybe this is a bug and not that you are stumped :).
I like your concept of adding the ring wave file to a call handler and then passing it on to the message call handler. I will give this a try and report back.
Awesome idea!
Phil
01-25-2013 12:31 PM
I just tested this and it does exactly as you said. Thanks for your workaround and time!
I may open up a TAC case to see if they can look into this and will post back if they come up with anything.
Thanks again,
Phil
