03-20-2013 09:36 AM - edited 03-16-2019 04:22 PM
Hello all,
Does anyone here on the forums know if there is a way to remotely access and rerecord a call handler greeting? We are trying to set something up for a client where they can dial into our Unity Connection and update the call handler greetings remotely?
We are running Unity Connection 8.5.1. Please let me know if you do.
Thank you.
Rgds,
Vicky
03-20-2013 09:51 AM
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
03-20-2013 10:25 AM
Hi Java,
Thank you for the reply. If I set up one number to give external access the Unity Greeting Administrator, can I lock it down to just the one Call handler or will this give the caller access to all of the call handler greetings?
Just want to double check this.
Please let me know.
Thanks.
Rgds,
Vicky
03-20-2013 10:28 AM
Hi Vicky,
Hope all is well buddy
I'll just add this to the good info from our friend Java (+5 "J")
You can have multiple ways to reach the Greetings Administrator Conversation.
It's nice to have a number that can be reached from outside the office using
a DID # so that Greetings for Call Handlers can be changed in case of an emergency
or "bad weather" day
One of the easiest ways is to just map a key off an existing Call Handler via - "Caller input" >
You can even put a button on your phone, with a "Direct" routing rule to the
Greetings Administrator Conversation if you have to change these all the time.
***NOTE: that when I followed the guide (above) I had to use a Forwarded Routing Rule
and I'm not sure the doc was ever changed. If you want to lock this down, just use Call
Handler "Owners" instead of the Greeting Admin role. That way the owner can only change greetings for their
own Call Handelrs.
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
03-20-2013 12:06 PM
Hello my friend!
Yes this works perfectly. I set up an owner to grant access to for the call handlers for the client.
Thank you and Java for the help here!!
Always great to hear from you.
Rgds,
Vicky
