unity connection unified msging email delivery
hi just got a question regarding unity connection 8.6 unified messaging with exchange 2007.  when someone leaves a msg to me (either internal/external), i recieve the email fine with wav file attached. however, when i read that email, the envelop icon does not become opened envelop.  at least thats the normal behavior for other emails.
attached pic will show you an example of unity con email after reading it. and a regular email. pls let me know your thoughts.
thanks
vijay
Jonathan Schulenberg
This is expected behavior per the product documentation.
Note Even if all the messages in your Inbox are in the Read state, the Outlook envelop icon still remains closed.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user/guide/email/8xcucugemail030.html
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq03037
Special thanks to Brad for tracking down the doc to prove this one!
Please remember to rate helpful responses and identify helpful or correct answers.
yahsiel2004
Level 7
Level 7
What happens when you hit the Send\Recieve on your Outlook, after listening to your voicemail?
Yosh
HTH Regards, Yosh
same issue. envelop icons do not open up.
nice thanks
