Unity Connection Wav File
Neal haas
Level 3
Level 3
I have a department that is creating WAV files for Unity Conn they ar
e setting the sampling rate to the highest, Unity connection is not excepting this. What is the correct Sa
mpling rate for Unity? G.711 of course.
Thank you
David Hailey
This would be codec-based so for G.711, I believe that would be 64 kbit/s.
Hailey
Please rate helpful posts!
Actually, 64kbs would be the line rate. The sampling rate should be 8 kHz/second with 8 bit samples (thus 64kbps). You can use an audio editing application to check the sampling rate.
See the following table for sampling rate and other pertinent information:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/7x/design/guide/7xcucdg025.html#wp1069840
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
