Unity Express Customer Script Help
angel-moon
Level 3
Level 3
Hello everyone,
I am being told I need a custom script for Unity Express.  The goal is to have the same caller input allowed (press 1 for blah blah blah) after the closed greeting is played that is allowed when the open greeting is played.  For this script it would just mean playing the main menu after the closed greeting plays.  Anyone have any thoughts on that?
Thanks in advance.  All replies rated.
Rob Huffman
Hi Angel,
You are most welcome my friend
There are CUE 8.x script editors available. Here is the path for
CUE 8.5.1;
You may find this doc helpful as well
http://docwiki.cisco.com/wiki/Cisco_Unity_Express_--_Custom_Script_Editor_FAQs
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Rob Huffman
Hi Angel,
Maybe you could try sending an email;
Note:  Custom script support is not available through the regular Cisco  Technical Support. For questions, comments, and help with a custom  script, send an email to;
ask-cue-editor@external.cisco.com.
From this good doc;
Unity Express Custom Scripts Quick Start Guide
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008041d950.shtml#integration
Cheers!
Rob
Thanks as always Rob.  Do you know where I can download a script editor from?  Other than logging onto a UCCx system?
Rob Huffman
Hi Angel,
CUE 8.5.1;
Cheers!
Rob
