10-25-2022 02:11 AM
Hello there!
I have Unity version 11 and I would like to forward my voicemail to my gmail account address.
It is possible? How can I do it?
Thanks in advance
10-25-2022 02:36 AM
Under SMTP configuration, set a smart host as email relay
Under user --> message actions --> set voicemail to "accept and relay the message" and an your email in the email field.
explained here: https://www.youtube.com/watch?v=EE0y4_zUn0w
10-25-2022 02:52 AM
thanks for the reply! What do you mean with "Smart Host"?
10-25-2022 02:59 AM
Check the video.
A smart host is an email relay server, the forwards the emails in the name of the unity. You need to configure it in Unity. Without it, Unity cannot send emails.
10-25-2022 03:24 AM
Refer the below video
https://www.youtube.com/watch?v=pJlKO5pNQRo
Go through the below guide.
10-25-2022 11:28 PM
@angelito_mas Any update on this issue?
10-26-2022 01:28 AM
No, I have Google Workspace, I have enabled SMTP Relay into Google Workspace Admin Console and in Unity I configured my e-mail domain and the address "smpt-relay.gmail.com" as Smart Host.
I cannot set up a server with SMTP Role in this moment.
How can I solve?
10-26-2022 01:39 AM
I don't know anything about Google services.
If you followed the steps in the video for the Unity configuration, then there is nothing else to do there.
If it is not working, then you need to check the network settings, if Unity can reach the SMTP relay or check the config in Google.
What you mean with "I cannot set up a server with SMTP Role in this moment."? Where do you wanna setup a "role"? If you have problems on the Google side, then you better ask in the google forums.
10-26-2022 01:48 AM - edited 10-26-2022 01:48 AM
I thought to set up a win server that acts as smtp server (and as Smart Host) but for the moment it is not possible.
I cannot access to Unity through CLI with my admin credentials, i m thinking that maybe it has a not correct network configuration.
It' s likely that this user is not enabled to access to the CLI? How can I verify it?
10-26-2022 01:55 AM
There are 2 different users for the application admin page and the CLI / os admin page. So, you need to get a different user for the CLI / for the os admin page.
10-26-2022 08:56 AM
Ok, i set up a server as Smart Host but from CLI i cannot ping it. There is no route in the routing table.
Can I add it through the CLI?
10-26-2022 11:02 PM - edited 10-26-2022 11:04 PM
Unity will just use it's default GW, to route packets outside it's subnet. If you can't ping it, you need to check your network.
Don't forget to check any firewalls. Since you are using a Google service, which will have a public IP, Unity probably will go to the internet to reach the Google servers and I'm 99% sure, the traffic will go through one or more firewalls in your network.
