Unity Subscriber Message Quota Maximum
Can the Unity Connection System Maximum of 2GB be overridden in any way?  We have a client with several executives that wish to exceed this limit.
Brian
5 Replies 5
islam.kamal
Level 10
Level 10
can you find the below link , please ?.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag190.html
Thank you
please rate all useful information
This isn't what I was looking for. I am looking for ways to exceed the system maximum.
Question #2 (and what may have been the actual client question):  What if the Exchange email box exceeds the Unity maximum of 2GB?   I'm fairly certain this has no impact on the Unity side as quotas are based on voice messages only, not Exchange-side emails.
Assistance appreciated.
Rob Huffman
Hi Brian,
For Q#1 - we have used this for a few peeps
To Specify Custom Mailbox Size Quotas for an Individual User or Template
Step 1 In Cisco Unity Connection Administration, find the user account or template that you want to edit.
Step 2 On the Edit menu, select Mailbox.
Step 3 On the Edit Mailbox page, set values for the applicable settings by selecting Custom and then entering a value (in megabytes) in the adjacent field:
Warning Quota
Send Quota
Send/Receive Quota
Note that the value for Warning Quota must be smaller than or equal to  the value for Send Quota, and the value for Send Quota must be smaller  than or equal to the value for Send/Receive Quota.
Step 4 Select Save.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmac040.html#wp1276635
For Q#2 - your assumption is most correct.
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Always good news when you respond Rob.
For #1 I have a problem though. I tried to exceed the 2GB max and Unity complained.
I'm thinking #2 makes #1 a moot point. Apparently some IT exec at one of our clients got ahold of a tech docs that said something about Single Inbox, Exchange 2k10 and mailbox limits of 2GB are a problem. I'm awaiting a copy of this source techdoc for more clarification.
Rob Huffman
Hi Brian,
Good stuff buddy
If they need more than 2048 MB something must be amiss.
On our system the defaults are 12,14,16 MB respectively so if we want
to add some extra space for a bigwig we might go to 20,22,24 which gives
them a fair bit more message space. I think you need to adjust your numbers down
accordingly.
Cheers!
Rob
- The Band
