unknown protocol drops on voice router 2921
tata123456
We are getting unknown protocol drops cisco voice  router 2921. We are facing  sometimes NO AUDIO  issue with cisco IP Phones.
When they are dialing exten to exten. How to resolve pls advise ASPL.
 IOS ver is c2900-universalk9-mz.SPA.152-4.M3.bin.
sh int gi 0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is e02f.6d66.0b70 (bia e02f.6d66.0b70)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
Internet address is 10.100.1.2/23
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:18:52
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 36000 bits/sec, 33 packets/sec
5 minute output rate 29000 bits/sec, 23 packets/sec
38644 packets input, 5375551 bytes, 0 no buffer
Received 11723 broadcasts (0 IP multicasts)
0 watchdog, 21 multicast, 0 pause input
27223 packets output, 4307813 bytes, 0 underruns
1936 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Manish Gogna
To troubleshoot no audio issues you need to get the debugs from the gateway to check the signaling and packet captures to trace the RTP flow. Assuming its SIP or h323 you can get the following debugs for a no audio issue
debug voice ccapi inout
debug ccsip messages
A packet capture from the IP phone and gateway would be helpful in tracking the issue completely.
Manish
Tagir Temirgaliyev
disable the DTP on switch end by "switchport nonegotiate" command on interface level. and no more protocol errors on the router end.
and I dont think it causes no audio. you will need ip packet capture to find your error
