Unlock IP phone 7821 settings
Hello All,
We are trying to unlock settings menu on a newly purchased 7821 phone. Hitting the Settings button and ** # doesn't work and the parameters are still shaded. We have also tried to do a Factory Reset, even thought it's a new phone, but nothing change and Settings menú is still locked.
Any idea?
Thanks in advance.
6 Replies 6
Leo Laohoo
Is the phone loaded with 3PCC/MPP or Enterprise firmware?
Hi Leo,
Enterprise Firmware.
Thanks.
AS far as i know the ** #  is for 79XX phones and 7821 i never seen such an method to unlock.
Response Signature
Not in access to a CM webUI at the moment so I cannot check, but isn’t there a configuration for this under device specific configuration on device in CM? It’s something with allow users to access settings or similar.
Response Signature
Had a look in CM when at work today. Either you set it on the individual device in CM by this.image.png
Response Signature
Hi Roger,
Yes, we had already checked this parameter and it's set to "enabled"
Thanks¡
