03-22-2011 12:08 AM - 편집 03-16-2019 04:04 AM
Hi all,
If my Call manager MCS7825I4-K9-CMC2 upgrade from 7.1 to 8.5 and Unity Connection Server MCS7825I4-K9-UCB1 upgrade from 7.x to 8.5, what software I want to order from CISCO ? Are the hardware compatable with the 8.5 ?
Thanks a lot
Leung Che Man
해결되었습니다! 솔루션으로 이동.
날짜: 03-22-2011 06:36 AM
Hello Leung,
check the file belwo :
this is the ordering guide , for the unity connection there something called software upgrade only part , check it , this is what you need.
Hope this was helpful.
Amer
날짜: 03-22-2011 06:43 PM
Hi Amer,
Thanks so much
Leung Che Man
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
