Upgrade paths and Software compatibility matrix
richb1971
Level 4
Level 4
I'm really struggling to find the upgrade paths from 6.1(x) to 6.1.5 (or any other for that matter). I also cannot find the software compatibility matrix anywhere. Most URLs point me to the same page - http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_device_support_tables_list.html
but I cannot find either doc anywhere. I can see the hardware matrix but where are the upgrade paths and software matrix??
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html.
These two are the same page which is of no help.
Rich
3 Accepted Solutions
Hello Rich,
The document has been removed from cisco web-site , i don't understand why ??????????????
Amer
Hello ,
I found this somewhere online some time ago , it can helpful considering the circumstances
Hello Richard,
I will open a PDI for this , this is really major problem.
However i do have one document , it is a little bit old but it has the 6.1 maybe it can be helful. Attached..
Amer
11 Replies 11
You are upgrading within the same version (6.1) this is not considered as a major upgrade , this is a minor upgrade.
Amer
Amer,
Thanks for reply. I realise its a minor version but where are software compat matrix and the upgrade path docs?
Rich
Hello Rich,
Amer
Hello ,
Thanks Amer. I thought I was going mad. Very frustrating. Any reference to those docs takes you to a general compatibility page with no mention of them.
Hopefully someone from Cisco can explain......
Hello Richard,
Amer
Thanks again Amer.
I'm trying to upgrade CUCM from 6.1.1 to 6.1.5 but get this message during start of upgrade:
upgrade_install.sh|Upgrade the system|<:INFO>
05/05/2011 14:09:39 upgrade_install.sh|-rwxr-xr-x    1 root     root        29874 May  5 14:05 /common/download/6.1.5.13900-4/Cisco/base_scripts/upgrade_manager.sh|<:DEBUG>
05/05/2011 14:09:39 upgrade_install.sh|Start upgrade manager|<:INFO>
05/05/2011 14:09:39 upgrade_install.sh|/common/download/6.1.5.13900-4/Cisco/base_scripts/upgrade_manager.sh type=upgrade             basepath=/common/download/6.1.5.13900-4             logfile=/var/log/install/install_log_2011-05-05.13.34.45.log             resultfile=/var/log/install/upgrade-results.xml|<:DEBUG>
05/05/2011 14:09:39 upgrade_manager.sh|Upgrade from 6.1.1.2000-3 not allowed|<:ERROR>
05/05/2011 14:09:39 upgrade_install.sh|Cleaning up download...|<:INFO>
05/05/2011 14:09:39 upgrade_install.sh|Removing /common/download/6.1.5.13900-4|<:INFO>
05/05/2011 14:09:39 upgrade_install.sh|Cleaning up rpm_archive...|<:INFO>
05/05/2011 14:09:39 upgrade_install.sh|Removing /common/rpm-archive/6.1.5.13900-4|<:INFO>
05/05/2011 14:09:39 upgrade_install.sh|CSA Status = 0|<:DEBUG>
05/05/2011 14:09:39 upgrade_install.sh|/etc/init.d/ciscosec start|<:INFO>
05/05/2011 14:09:41 upgrade_install.sh|(CAPTURE) Starting ciscosec:  [  OK  ]|<:DEBUG>
05/05/2011 14:09:41 upgrade_install.sh|Stop IOWAIT monitor|<:INFO>
Then the upgrade fails. This is upgrading to 6.1.5.13900-4.
Any ideas?
Hi Rich,
Here is the info for the release you are trying to load 6.1.5.13900-4 which is 6.1(5)su3
NoteYou can only install this Service Update on Cisco Unified Communications Manager Release 6.1(3x), 6.1(4x), 6.1(5), 6.1(5)su1, 6.1(5)su2 or any 6.1(5)es from 6.1.5.11001-1 to 6.1.5.13036-1..
From the readme that links when you actually download the Software;
http://www.cisco.com/web/software/282074295/46481/cucm-readme-615su3.pdf
It looks like the base 6.1(5) version can be upgraded from 6.1(1x)
Upgrading From Cisco Unified Communications Manager Release 6.1(1x) or higher to Release 6.1(5) by Using the UCSInstall File
Because of its size, the UCSInstall iso file, UCOS_6.1.5.xxxx-x.sgn.iso, comprises two parts:
UCSInstall_UCOS_6.1.5.10000-10.sgn.iso_part1of2
UCSInstall_UCOS_6.1.5.10000-10.sgn.iso_part2of2
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/rel_notes/6_1_5/cucm-rel_note-615.html#wp396072
Cheers!
Rob
PS: I'm working on getting the "great" doc back online
ITS BACK!!!! Woohoo
Thanks Rob and anyone else who battered Cisco to get this resolved.
Rich
Rob Huffman
Hi Rich,
I agree my friend YAHOO!!
Here's the saga (we can thank Mary from Cisco for helping us all out here);
https://supportforums.cisco.com/message/3351891#3351891
Cheers!
Rob
