upgrading from cucm 7.1.2 to 7.1.3 in Vmware
CLIFFORD BARTLE
Hi, can anyone tell me if CUCM 7.1.3 runs ok in VMWARE (ESX3.5) I am trying to upgrade but when it re-boots I get error of :
kernel panic- not syncing: attempted to kill init
thanks
Cliff
2 Accepted Solutions
I ran into the same issue (vmware ESXi) when upgrading 7.1.2 to an early release of 7.1.3 (sorry, don't
remember exactly which release). I restored 7.1.2 and upgraded to a later version (7.1.3aSU1) and was successful with the upgrade.
On CUCM 7.1.2, there's no code to detect VMWare.  Thus you may install it on any Vitual Machine.  CUCM just thinks it's a physical one.
On CUCM 7.1.3, Cisco added code to detect VM.  You'll have to use ESX 4.
Michael
9 Replies 9
William Bell
Cliff,
I have used this on ESXi 3.5 but I have run CUCM (all versions from 4.1 to 7.1.3bsu2) in vmware server 2.0 without any issues.  Not the exact scenario you are look at I know, but it's what I have tested.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
thanks guys for your responses, i have now intalled 7.1.3 on vmware, my findings below:
-first of all i was actually trying to install it on esx 3.0 appologies
-7.1.2 bombs out in vmware if you dont configure a viable NTP server
- you cant upgrade from 7.1.2 to 7.1.3 in vmware esx 3.0 not sure why, but have heard license files are different
- i got a bootable copy of 7.1.3 to install fresh on vmware 3.0 but couldnt do it
- eventually upgaded vmware to esx 4.0 all good, you still need a viable ntp server
hope this helps someone
cliff
fill your boots
Michael
Thanks Michael, would be nice if that bit of code put up a message saying that, I spent a lot of time trying to shoe horn this on an inappropriate version!
regards
Cliff
I have ESX 4 Update 1 and still can't upgrade from 7.0.2, or 7.1.2 to 7.1.3. I wish there was a clear solution to that.
THanks
What's your VM spec?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Here you go... I've also tried RH 3, and created vm on Fusion 3, same result. In every case log was complaining about platform (vmware) no longer supported...
thx
#!/usr/bin/vmware
.encoding = "UTF-8"
config.version = "8"
virtualHW.version = "7"
pciBridge0.present = "TRUE"
pciBridge4.present = "TRUE"
pciBridge4.virtualDev = "pcieRootPort"
pciBridge4.functions = "8"
pciBridge5.present = "TRUE"
pciBridge5.virtualDev = "pcieRootPort"
pciBridge5.functions = "8"
pciBridge6.present = "TRUE"
pciBridge6.virtualDev = "pcieRootPort"
pciBridge6.functions = "8"
pciBridge7.present = "TRUE"
pciBridge7.virtualDev = "pcieRootPort"
pciBridge7.functions = "8"
vmci0.present = "TRUE"
nvram = "CUCM.nvram"
deploymentPlatform = "windows"
virtualHW.productCompatibility = "hosted"
unity.customColor = "|23C0C0C0"
tools.upgrade.policy = "useGlobal"
powerType.powerOff = "default"
powerType.powerOn = "default"
powerType.suspend = "default"
powerType.reset = "default"
displayName = "CUCM"
extendedConfigFile = "CUCM.vmxf"
scsi0.present = "TRUE"
scsi0.sharedBus = "none"
scsi0.virtualDev = "lsisas1068"
memsize = "2048"
scsi0:0.present = "TRUE"
scsi0:0.fileName = "CUCM.vmdk"
scsi0:0.deviceType = "scsi-hardDisk"
ide1:0.present = "TRUE"
ide1:0.fileName = "/vmfs/volumes/49d3dcf7-371d5df0-6689-0025b3829d18/ISO images/UCSInstall_UCOS_7.1.3.20000-2.sgn.iso"
ide1:0.deviceType = "cdrom-image"
ethernet0.present = "TRUE"
ethernet0.networkName = "192.168.68.0"
ethernet0.addressType = "vpx"
ethernet0.generatedAddress = "00:50:56:af:28:95"
chipset.onlineStandby = "FALSE"
guestOSAltName = "Red Hat Enterprise Linux 4 (32-bit)"
guestOS = "rhel4"
uuid.bios = "42 2f 9c d7 24 2e e8 9e-43 c2 6d a8 2d 54 22 8a"
vc.uuid = "52 49 ad 68 46 5f 55 0d-4f 7a 50 b4 85 2d da e5"
snapshot.action = "keep"
sched.cpu.min = "0"
sched.cpu.units = "mhz"
sched.cpu.shares = "normal"
sched.mem.minsize = "0"
sched.mem.shares = "normal"
tools.syncTime = "FALSE"
uuid.location = "56 4d b1 ed a1 fb c0 12-b3 1d f9 c2 c0 29 52 48"
cleanShutdown = "TRUE"
replay.supported = "FALSE"
sched.swap.derivedName = "/vmfs/volumes/4b9bca98-8ea91cca-6297-0025b3829d18/CUCM/CUCM-37be9470.vswp"
scsi0:0.redo = ""
vmotion.checkpointFBSize = "4194304"
pciBridge0.pciSlotNumber = "17"
pciBridge4.pciSlotNumber = "21"
pciBridge5.pciSlotNumber = "22"
pciBridge6.pciSlotNumber = "23"
pciBridge7.pciSlotNumber = "24"
scsi0.pciSlotNumber = "160"
ethernet0.pciSlotNumber = "32"
vmci0.pciSlotNumber = "33"
scsi0.sasWWID = "50 05 05 67 24 2e e8 90"
vmci0.id = "760488586"
tools.remindInstall = "TRUE"
hostCPUID.0 = "0000000b756e65476c65746e49656e69"
hostCPUID.1 = "000106a500100800009ce3bdbfebfbff"
hostCPUID.80000001 = "00000000000000000000000128100800"
guestCPUID.0 = "0000000b756e65476c65746e49656e69"
guestCPUID.1 = "000106a500010800809822010febfbff"
guestCPUID.80000001 = "00000000000000000000000128100800"
userCPUID.0 = "0000000b756e65476c65746e49656e69"
userCPUID.1 = "000106a500100800009822010febfbff"
userCPUID.80000001 = "00000000000000000000000128100800"
evcCompatibilityMode = "FALSE"
debugStub.linuxOffsets = "0xde8c368,0xffffffff,0xde8c387,0x0,0xfc052088,0xffffffff,0x0,0x0,0xde8cbe8,0x0,0xde8cbff,0x0,0xfc05219c,0xffffffff"
bios.forceSetupOnce = "FALSE"
numvcpus = "1"
floppy0.present = "FALSE"
