Upgrading Phone Firmware: Is Install on PUB Required vs Only Nodes Running TFTP?
L.K.
Kindly assist me with the below.
When installing a new firmware file on a CUCM cluster should I always install it on the PUB and TFTP subscribers, or can I simply install it on the TFTP subscribers?
I will be using the cop install method. Our PUB does not run TFTP services. We have two dedicated subscribers running TFTP services.
What is the Cisco recommended and approved process? What is best practice? Does Cisco support installing the firmware only on TFTP nodes?
L. K. | Consultant, Lead Senior Engineer, Specialist | Cisco Unified Communications
Justin,
That is incorrect. Individual firmware files, or the COP files, DO NOT need to be installed on the PUB, or any NON-TFTP subsequent SUB, MOH nodes. Regular phone specific new firmware versions/updates need only to be applied to the TFTP nodes. This can be done via COP install (preferred) or manually via the ZIP contents.
This method also helps reduce the unnecessary file management and storage used on the clusters' nodes, as well as decreases the DRS size.
The only time this is required on PUB (and potentially rest of the cluster) is when installing Device Packs*.
* There may be very rare cases where the new individual firmware adds/removes/updates CUCM code for configuration of a new feature within CUCM that is phone specific which may require it be installed on PUB and all nodes on cluster (e.g. a new phone specific configuration line item within CUCM Device page). From my research this is extremely rare, and pointed out within the release notes/read-me. If unsure can always reach out to TAC to inquire about this. I have not come across this situation yet, and Cisco informed me these kind of firmware updates are typically deployed within Device Packs.
10 Replies 10
Chris Deren
Technically firmware files are only needed on the TFTP nodes as those are the only nodes that will serve them.  Installing it on the Pub allows it to change the device defaults page, plus it's a good idea to keep the files consistent in case you at some point decide to turn on TFTP service on other nodes if TFTP node goes down, etc. I always install firmware files on all nodes even on large multi-node clusters with only 2 TFTP nodes in the cluster, does not take that much more time, especially if you use PCD to install it or use automated tool (I built one to push files directly to TFTP store).
Thanks for the response.
That is typically what I have done in the past. Currently this cluster is very large, PUB, 8 CM SUBs, 2 TFTP SUBs, 2 MOH SUBs. They ran into issues with DRS backup size from firmware files on all nodes and only want to install on the TFTP SUBs manually.
Would you know any specific details on what the COP install files actually does? Does the COP file simply only extract the firmware loads, and update the device defaults if it is installed on a PUB? Does it do anything additional at all beyond that?
Are there any negative sides to NOT installing it on the PUB, and only the TFTP SUBs?
Also @Chris Deren I am very curious about your automated tool you built (to push files directly to TFTP store). Would you be willing to share this with me? Or at the code please? I would greatly like to look into this and would be much appreciated.
Thanks again!
All software packages MUST be installed on the PUB, during the "installation" process DB changes are made, which can only happen on the PUB.
Justin Ferello
Justin,
Even if dev packs technically don't need to be installed on all nodes in a cluster this is what the official documentation says about this.
Response Signature
Correct. I included the asterisk note to point this out:
This process applies to individual firmware upgrades.
You can get the tool from
https://github.com/cderen/CUCMFirmwareUpload.git
there is the python code as well as .exe you can use from Windows PC. Simply put all files into /Folder folder and run the tool with arguments "hostname" "username" "password" "CUCM version i.e. 12.5"
example: CUCMFirmwareUpload.exe 10.1.1.1 admin cisco 12.0
L.K.
Here is a write up of the steps to take:
STEPACTIONNOTES / OUPUT
1Upload desired COP install file to SFTPApp calculates MD5 hash of selected firmware file pm SFTP
2Complete your desired cluster/node pre-checks
3Note MD5 hash of new firmware COP file
4Access CLI, console or SSH, of TFTP1 node (Primary)
5Run
show status
CLI outputs current node status and basic details
6Run
show version active
CLI outputs current version and installed files
7Run
utils service list
CLI outputs current running services
8Run
show tech devdefaults
CLI outputs current device default firmware loads
9Run
utils system upgrade initiate
to begin update
CLI output
Warning: Do not close this window without first canceling the upgrade.
Source:
 1) Remote Filesystem via SFTP
 2) Remote Filesystem via FTP
 3) Local DVD/CD
 q) quit
Please select an option (1 - 3 or "q"
10Enter 1 for SFTP install
11Enter SFTP server details:
Directory []:
Server []: <SFTP-IP>
User Name []: <username>
Password: <password>
Please enter SMTP Host Server (optional):
CLI output
Checking for valid upgrades.  Please wait...
Available options and upgrades in "000.000.000.000:""":
 1) cmterm-78xx.12-7-1-0001-393.k3.cop.sgn
 2) cmterm-8831-sip.10-3-1SR6-4.cop.sgn
 3) cmterm-8832-sip.12-7-1-0001-403.k3.cop.sgn
 4) cmterm-88xx-sip.12-7-1-0006-413.k3.cop.sgn
 q) quit
Please select an option (1 - 4 or "q"
12Enter corresponding number option to desired firmware fileCLI output
Accessing the file.  Please wait...
Downloaded 169 MB.
Checksumming the file...
Validating the file...
A system reboot is required when the upgrade process completes or is canceled.  This will ensure services affected by the upgrade process are functioning properly.
     Downloaded: cmterm-88xx-sip.12-7-1-0006-413.k3.cop.sgn
  File checksum : (MD5): f2:1d:34:e1:5a:28:fc:bb:70:dc:fb:06:04:af:26:3e
Start installation (yes/no):
13Compare and verify CUCM calculated MD5 hash matches
14Enter
yes
to start the firmware install
The install begins, scrolling the log/output on CLI
15Installed completedCLI output
Successfully installed cmterm-88xx-sip.12-7-1-0006-413.k3.cop.sgn
Locale cmterm-88xx-sip.12-7-1-0006-413.k3.cop has been installed successfully.   A reboot is not necessary for the changes to take effect.
16Run
show version active
Verify desired firmware install file is present in output list
17Run
utils service list
Verify "Cisco Tftp" is continuing running on node
18Repeat steps 4-17 for TFTP2 (Secondary)
19Repeat steps 4-17 for any additional TFTP nodes in cluster
20Access CUCM Web GUI
21Navigate to Device --> Device Settings --> Device Defaults
22Update the "Load Information" for the pertaining Device Types (models) with newly installed firmware version and Save
23Restart Cisco Tftp service on TFTP1 & TFTP2Verify the service is showing as started
24Restart Cisco Tftp service on any additional TFTP nodes in clusterVerify the service is showing as started
25Apply Config to the pertaining devices to push and upgrade phones to new firmware versionThis can be completed via BAT (Phone --> Update Phones --> Query)
26Monitor and allow time for phones to download/upgrade firmware
27For all TFTP nodes return to CLI and run
show status
28For all TFTP nodes return to CLI and run
show version active
29For all TFTP nodes return to CLI and run
utils service list
Verify services are running as previously, including "Cisco Tftp"
30For all TFTP nodes return to CLI and run
Verify new updated device default firmware loads listed for pertaining models
31Exit CLI
Hope this helps!
To add to your very detailed and excellent write up (+5). If you do want to install the firmware on all nodes in your cluster and you happen to run 12.5+ you can install it in one step by running this command on the publisher.
utils system upgrade cluster initiate
Response Signature
Thanks! Still on 11.5 and currently planning some upgrades to 12.5. This will definitely come in handy in the future! Especially for fix, CVE< vulnerability, etc COP file installs that require each node on a cluster!
