10-31-2013 04:25 AM - edited 03-16-2019 08:10 PM
hello everyone
i have a customer want update CUCM from 7.1.5 to 9
and i have update it OK on a VMware
but now they want use their MCS 7835 to run the CUCM 9.....
now can i use USB device to install ? because the CUCM 9 ios is too big then DVD.....
10-31-2013 04:35 AM
You will need to use a dual layer DVD for this which has a capacity of around 8.5 GB, USB is not supported for cucm install.
Manish
10-31-2013 05:06 AM
Hi Liu,
In addition to what Manish has said[+5] , u can upgrade the CUCM by keeping the patch on your PC [ through which CUCM is reachable] and upload the patch on to CUCM servers through SFTP like Freeftpd software by using GUI of OS administration [Software Upgrades--Software Installation/Upgrade] page.
regds,
aman
10-31-2013 05:21 AM
Hi Liu,
this upgrade would be a Refresh Upgrade and should be performed during maintenance window since servers reboot and system is not available during upgrade.
regds,
aman
10-31-2013 05:39 AM
In regards to using a MCS 7835, you may want to check the compatability guide here first. Note, some of the 7835 models only allow bridged upgrades. I would stray away from physical CUCM installs, as Cisco seems to be continuing to move towards their virtual model.
Best of luck!
